Printing A Face Normal To A File
Hello world,
I am setting a face to have a face normal,
polySetToFaceNormal;
I am trying to query a face to get the face normal from "polyInfo -fn polySurface12.f[0]"
This returns : "// Result: FACE_NORMAL 0: -0.688109 0.000000 -0.725608 //
so far so good.
but when I try to put this result into something like
$zxc = polyInfo -fn polySurface12.f[0];
then I get this
// Error: Cannot convert data of type string[] to type float. //
I am surely doing something wrong.
can anyone help.
thank you
ken
The error comes up becauce polyInfo returns a string, not a float, so you should instead use:
string $zxc[] = polyInfo -fn polySurface12.f[0];
And because polyInfo returns a string and not a vector directly, you will have to tokenize that string to remove all the unwanted characters.
You can use Bryan Ewert's function to do this:
proc vector translatePolyInfoNormal( string $pin )
  vector $normal;
  float $x;
  float $y;
  float $z;
  string $tokens[];
  int $numTokens = tokenize $pin " " $tokens;
  // Make sure we're looking at polyInfo data:
  if ( ( $numTokens > 3 ) && ( $tokens[0] == "FACE_NORMAL" ) )
    // Maya performs data-type conversion here.
    $x = ($tokens[$numTokens-3]);
    $y = ($tokens[$numTokens-2]);
    $z = ($tokens[$numTokens-1]);
    $normal = <>;
    // Normalize it.
    $normal = unit $normal;
  // Return it.
  return $normal;
For more info: http://www.ewertb.com/maya/mel/mel.php?howto=05
Thank you Thank you Thank you,
This example worked out great so far.
I am working out the fact that every once and a while I will get an errant value.
but that is for another day.
again thank you very much.
-ken
