hi
i want to composite hardware rended images with software rended images under CCIR_PAL/Quantel PAL 720 576 1.333 resolution.and i have done softwear rendering for all image sequence.and though i have selected above resolution from the Hardware rendering globals, the result is with 720*464. then i got a problem with composting with each.
as follows i got resulted with each resolution selected..
select from HR.globals resulted image resolution
320*240=======================> 320*240====>ok.
640*480=======================> 640*464====>???
1K_Square=====================> 1K_Square==>ok.
2k_Square=====================> 2K_Square==>ok.
CCIR_PAL/Quantel_PAL(720 576)===> 720*464====>???
CCIR_604/Quantel_NTSC(720 486)=> 720*464====>???
Full_1024 (1024*768)============> 782*464====>???
PAL_768 (768*576)==============> 768*464====>???
if that is my hardware probelm well i'm using NVdia 3D VGA card and 14 inches monitor...384 RAM and 886 MHz P3.
please help me as u can see, and i appreciate ur feed back....
thank you...
