Hey guys, I've recently started doing some modelling and playing around with dynamics for a uni project and I've ran into a problem which I hope you guys could help me with. I've modelled a balloon and its string in maya using ncloths, however the string is not attached to the balloon visually. I connected them by the vertex's using the component to component tool and it seems to work fine, however when you zoom in on the area where the balloon and string are supposed to be connected, it appears as there is an empty space between the two objects. I'm thinking maybe its something to do with the stretch resistance of both the objects not reacting properly? I've linked a jpeg of it below.
How can I fix this problem so that the balloon and string are connected properly? There's probably a super easy solution but its my first time working with these so mind my noobness
Any help would be appreciated, cheers
Chris
