So I've got a windows service setup to run jobs on render farm machines. We're running Maya, python, and aerender this way, no problems. I'm now moving into getting AfterFX.exe running this way as well, to automatically build comps, add layers to comps, etc. My first little test script worked fine.
app.exitAfterLaunchAndEval = true;
app.beginSuppressDialogs();
app.project.close(CloseOptions.DO_NOT_SAVE_CHANGES);
app.newProject();
var f = new File("\\server\target`08\testComp.aep");
app.project.save(f);
app.quit();
If I add in some lines that input image sequences, it works fine as well. However, the following script fails to stop execution when it is run as a service. The AfterFX.exe process just hangs, using 0 CPU until it is manually killed.
app.newProject();
var comp = app.project.items.addComp("Comp1", 720, 486, 0.9, 20.0, 25.0);
app.quit();
Now, if I run this from the command line, normally, it completes just fine. But there is apparently something about running it as a service that causes it to hang for ever.
Anyone have any experiences like this and know how to fix it?
thanks,
jesse
