Well, I managed, by using command/shift/click to select the main model and then in the tool /geometry palette to delete hidden. It worked, but now the model has a hole in his head.
But still, I am unable to use any of the transform modes! Also, when I move the double circle over the model to smooth it the circle doesn't follow my pen. it snaps from position to position. It used to follow smoothly!
Would reimporting it, or exporting to maya and reimporting it solve the problem?
Whoops, I just tried, after saving the tool and the document, closing zbrush, opening it again, and reimporting the tool but the document is greyed out and cannot be imported.
If I don't go nuts trying to get past things like this I might eventually learn the program!
Any more suggestions/reasons why these things are happening?
Robert
