I am using the Advanced Skeleton (V 1.5) rig for my character setup. After I set up my fit skeleton to match my character and press the Advanced Skeleton button to duplicate the other side, the lowest joint of the spine drops down to the feet. The rest of the skeleton is in the correct places. Now of course, this problem is easily fixed by simply moving the joints into place, but I am concerned that it may be an issue later on, with binding, keying, or texturing. Has anyone else experienced this? Any comments or suggestions would be very welcome
Thank you,
Tulane
Well I got an answer...there is a bug in the program, but they are working on it...I'm very impressed that I got a reply to my email within 2 hours on a Saturday! Advanced Skeleton is an awesome plugin, I definately recommend it
animationstudios.com.au
I have a problem with the plug inn too, I'm working with maya 3.0, the plug inn is correct installed- first i create the normel skeleton- but if i will create the advanced skeleton i can't give it the name i wont
whats wrong?
version 1.51 has been released.
this may fix the bug.
re cornelius
i have a big problem in face building when i reach to Lips :step 11 ,it give me error ( the maximum value must be greater than the lower value ) please give me your answers and Suggestions .
I also have the same problem..did you get a solution
