Problem With Loop And Attribute Control
Hallo
I am working on my own tank tread creation script. I know that there is one allready made, which works really great, but I want to make my own for learning purpose and I want to add some more options and control.
My problem here is the for() loop, as long as it it $i < 1 it works perfect, but if I increase it (eg. $i < 2) it returns this error:
Error: Attribute already controlled by an expression, keyframe, or other connection: TankTreadAnimationPath_0.uValue
The problem is in this line, as if I comment it out the script works:
$expr += (""+$pathAnimation+".uValue=fmod(((time*$speed)+("+$distance+"*"+$i+")),1)"+";\n");
I have looked at it for so long now, and I cant find out what I am doing wrong so I am in desperate help for some help.
Also, as I am still learning and other obvius misstakes in the script would be great to know about
How to use it:
Set path = a nurbs curve
set object = a object
//              Information
// Name: TankTreadGenerator
// Date: Pending
// Version:
// Author: Ole Kristian H. Homelien
// Mail: Ole_Kristian92@hotmail.com
// Description:
// Installation:
// How to Use:
    // Programing starts here, modefy at own risk
//Proccedure for making the UI
global proc OKHH_TankTreadGeneratorUI()
    //create the UI
    //Create the window
    string $window;
    if (window -exists myWin)deleteUI myWin;
    $window = window    -title "OKHH\_TankTreadGenerator Beta"
                -widthHeight 300 200
                myWin
    //create formLayout
    formLayout myForm;
    //---------Content
    textField objectTF;
    textField pathTF;
    text -label "Choose a orientation for the project:" orientationText;
    button -l "Set object" -command "OKHH_TankTreadGeneratorAddtoTextFieldObject()" objectButton;
    button -l "Set path" -command "OKHH_TankTreadGeneratorAddtoTextFieldPath()" pathButton;
    button -label "OK"  -command "OKHH_TankTreadGeneratorMain()" okButton;
    button -label "Close" closeButton;
    checkBox -label "Copy"        -align "left" copyBox;
    checkBox -label "Instance"    -align "left" InstanceBox;
    checkBox -label "Dynamic"    -align "left" DynamicBox;
    checkBox -label "X"    -align "left"    Xbox;
    checkBox -label "Y"    -align "left"    Ybox;
    checkBox -label "Z"    -align "left"    Zbox;
    //---------Content
    //---------Edit
    formLayout     -e
            -attachForm objectTF left 0
            -attachForm objectTF top 0
            -attachPosition objectTF right 0 75
            -attachForm objectButton right 0
            -attachControl objectButton left 0 objectTF
            -attachForm objectButton top 0
            -attachControl pathTF top 0 objectTF
            -attachForm pathTF left 0
            -attachPosition pathTF right 0 75
            -attachForm pathButton right 0
            -attachControl pathButton top 0 objectTF
            -attachControl pathButton left 0 pathTF
            -attachForm copyBox left 0
            -attachControl copyBox top 10 pathTF
            -attachForm InstanceBox left 0
            -attachControl InstanceBox top 0 copyBox
            -attachForm DynamicBox left 0
            -attachControl DynamicBox top 5 InstanceBox
            -attachForm orientationText left 0
            -attachControl orientationText top 5 DynamicBox
            -attachForm Xbox left 0
            -attachControl Xbox top 0 orientationText
            -attachPosition Xbox right 0 33
            -attachControl Ybox left 0 Xbox
            -attachControl Ybox top 0 orientationText
            -attachPosition Ybox right 0 66
            -attachControl Zbox left 0 Ybox
            -attachControl Zbox top 0 orientationText
            -attachPosition Zbox right 0 100
            -attachForm okButton left 0
            -attachControl okButton top 7 Xbox
            -attachPosition okButton right 0 50
            -attachControl closeButton left 0 okButton
            -attachControl closeButton top 7 Xbox
            -attachForm closeButton right 0
            myForm;
    //---------Edit
    //Show the window
    showWindow $window;
    //End of UI
//Proccedure for adding the object to the
//TextList for later use
global proc OKHH_TankTreadGeneratorAddtoTextFieldObject()
    string $object[]= ls -sl -flatten;
    int $noOfObjects = size($object);
    if ($noOfObjects == 1)
        print "\nObject added to the textField";
        textField -e -text $object[0] objectTF;
    else if ($noOfObjects == 0)
        print "\nYou have to select one object!";
    else if ($noOfObjects > 1)
        print "\nPlease select only one object!";
//Proccedure for adding the path object to the
global proc OKHH_TankTreadGeneratorAddtoTextFieldPath()
    string $object2[]= ls -sl -flatten;
    int $noOfObjects2 = size($object2);
    if ($noOfObjects2 == 1)
        print "\nPath object added to the textField";
        textField -e -text $object2[0] pathTF;
    else if ($noOfObjects2 == 0)
        print "\nYou have to select one object to use as the path!";
    else if ($noOfObjects2 > 1)
        print "\nPlease select only one object to use as  the path!";
//Proccedure for adding the treads to the tank
//And to automate the animation
global proc OKHH_TankTreadGeneratorMain()
    //---------Read information from the UI
    string $object = textField -q -text objectTF;
    string $pathCurve = textField -q -text pathTF;
    int $onOrOffCopy = checkBox -q -v copyBox;
    int $onOrOffInstance = checkBox -q -v InstanceBox;
    int $onOrOffDynamicBox = checkBox -q -v DynamicBox;
    int $onOrOffXbox = checkBox -q -v Xbox;
    int $onOrOffZbox = checkBox -q -v Zbox;
    int $onOrOffYbox = checkBox -q -v Ybox;
    //---------Error checking
    if ($onOrOffInstance == 1 && $onOrOffCopy == 1)
        warning("You cant have both copy and instances, pick One!");
        //Break
    if ($onOrOffInstance == 0 && $onOrOffCopy == 0)
        warning("You have to select copy or instance");
        //Break
    if ($object == "")
        warning("You must select a object to be used in this script!");
        //Break
    if ($pathCurve == "")
        warning("You must select a path curve to be used in this script!");
        //Break
    if (($onOrOffXbox + $onOrOffYbox + $onOrOffZbox) != 1 )
        warning("You can not have two project orientations, pick One!");
        //break
    //---------Find the lenght and orientation of the curve and the object
    string $orientation;
    float $objectLength;
    //Length of the curve
    float $lengthCurve = arclen -ch 0 $pathCurve;
    //Orientation of the project
    if ($onOrOffXbox ==1)
    $orientation = "X";
    if ($onOrOffYbox ==1)
    $orientation = "Y";
    if ($onOrOffZbox ==1)
    $orientation = "Z";
    //Length of the object
    float $objectBoundingBox[] = exactWorldBoundingBox $object;
    if ($orientation == "X")
    $objectLength = abs($objectBoundingBox[0] - $objectBoundingBox[3]);
    if ($orientation == "Y")
    $objectLength = abs($objectBoundingBox[1] - $objectBoundingBox[4]);
    if ($orientation == "Z")
    $objectLength = abs($objectBoundingBox[2] - $objectBoundingBox[5]);
    //Number of objects needed to cover the curve:
    float $noOfObjects = $lengthCurve / $objectLength;
    int $realAmountObjects = $noOfObjects;
    float $gapBetweenObjects = ($noOfObjects - $realAmountObjects) / $realAmountObjects;
    //---------Make the treads and set up the animation
    //Making an animation control
    select $pathCurve;
    xform -cp $pathCurve;
    float $pathCurveCenter[] = xform -q -ws -piv;
    string $animationControl[] = spaceLocator -p 0 0 0;
    addAttr -ln SpeedControl -at double  ("|"+$animationControl[0]);
    setAttr -e -keyable true ("|"+$animationControl[0]+".SpeedControl");
    xform -translation $pathCurveCenter[0] $pathCurveCenter[1] $pathCurveCenter[2] $animationControl[0];
    //Parent the animation control to the pathCurve
    //parent $pathCurve $animationControl[0];
    //-------Animate the treads
    for($i = 0; $i < 2; $i++)
        select $object;
        //duplicate the tread
        if($onOrOffCopy == 1)
            duplicate -rr;
        if($onOrOffInstance == 1)
            instance;
        //Make a path animation
        string $newObject[0] = ls -sl;
        string $objectCopy = $newObject[0];
        string $pathAnimation = pathAnimation    -fractionMode false
                            -follow true
                            -followAxis x
                            -upAxis y
                            -worldUpType "vector"
                            -worldUpVector 0 1 0
                            -inverseUp false
                            -inverseFront false
                            -bank false
                            -startTimeU 1
                            -endTimeU 150
                            -n ("TankTreadAnimationPath\_"+$i+"")
                            -c $pathCurve $objectCopy
        //delete the pre-made connection
        select $pathAnimation;
        CBdeleteConnection ("TankTreadAnimationPath_"+$i+".u");
        //Calculate the distance between each thread object
        //Stuff
        print"\n";
        print $pathAnimation;
        print "\n";
        print $objectCopy;
        float $distance = 0.3;
        //Make a new connection
        string $expr ="";
        $expr += ("float $speed = "+$animationControl[0]+".SpeedControl"+";\n");
        //uValue is connected to the pathAnimation
        expression    -s $expr
                -o $pathAnimation
                -ae 1
                -uc all;
//$object
//$pathCurve
