QUOTE(panteruga @ 09/12/08, 02:08 PM) [snapback]291563[/snapback]
Hy guys,
I got little Problems with my Fusion Composition..
I try to explain the problem:
I want to merge two sequence animations ( .Jpg files)..
I have imported the sequences in two Loader nodes;
I have created the Merge node and I connected the first animation to the Background input and the second one to the Foreground input and I set the screen mode.
and here there is the problem!!
The Merge node works only until the frame 301 ( that corrispond to the duration of the first animation!)
How can I do to extend the merge operation to the end of the second animation (frame 750)?
Thanks a lot in advance
Either you can loop the FG sequence or loop it.
