Hey Guys I wrote this script, but can someone tell me why this script does not work on a larger file i have? It works fine on simple files...but it points 3000 objects in another scene i have and i know the objects are connected. It just finds out some shapes i cant even see!
thanks,
Daniel Moreno
www.danmoreno.com
// check shader
if (window -ex check == 1){
deleteUI check;
window -t "Shader Check" -sizeable 1 -resizeToFitChildren 0 -widthHeight 300 150 check;
columnLayout -rowSpacing 5;
frameLayout -cll 1 -label "Check" -w 300 -borderStyle "in";
rowLayout -columnWidth3 295 1 1 -numberOfColumns 3;
button -l "Check Unshaded and Default Shaded Objects!" -w 295 -c check_shader -annotation "Checks for Objects with No Shader and Default Shader" checkButton;
text -label " " -w 1 unshadedobj;
text -label " " -w 1 defshadedobj;
setParent ..;
rowLayout -columnWidth2 145 145 -numberOfColumns 2;
button -l "Select Unshaded" -w 140 -c select_unshaded -annotation "Select Objects with No Shader" checkButton;
text -label "Unshaded" -w 145 -fn "boldLabelFont" unshadedtext;
setParent ..;
button -l "Select Default Shaded" -w 140 -c select\_Defshaded -annotation "Select Objects with Default Shader" checkButton;
text -label "Default shaded" -w 145 -fn "boldLabelFont" defaultshadedtext;
setParent ..;
setParent ..;
setParent ..;
$progressCTRL = `progressBar -maxValue 100000 -width 300 -h 10 checkprogress`;
setParent ..;
showWindow check;
global proc check_shader(){
string $allgeometry[] = ls -geometry;
int $ok;
string $shader[];
string $boladavez[];
global string $noshader[];
global string $defaultshader[];
int $n = 0;
int $d = 0;
int $ponto =size($allgeometry);
$ponto = 100000 / $ponto;
for ($obj in $allgeometry) {
$boladavez = `ls -showType $obj`;
switch ($boladavez[1]) {
case "mesh":
$ok = 1;
break;
case "nurbsSurface":
$ok = 1;
break;
case "subdiv":
$ok = 1;
break;
default:
$ok = 0;
break;
progressBar -edit -step $ponto checkprogress;
if ($ok = 1){
$shader = `listConnections -source true -type shadingEngine $obj`;
if (size($shader) == 0){
print ("Object " + $obj + " has no shader! \n");
$noshader[$n] = $obj;
$n = $n + 1;
} else {
for ($sg in $shader) {
if ($sg == "initialShadingGroup") {
print ("Object " + $obj + " still have the Initial Shading! \n");
$defaultshader[$d] = $obj;
$d = $d + 1;
text -e -label (size($noshader) + " Unshaded") -w 145 unshadedtext;
text -e -label (size($defaultshader) + " Default shaded") -w 145 defaultshadedtext;
progressBar -edit -step (-100000) checkprogress;
print (size($noshader) + " not shaded, " + size($defaultshader) + " default shaded \n");
string $noshader_;
for ($obj in $noshader){
$noshader_ = $noshader_ + "~" + $obj;
string $defshader_;
for ($obj in $defaultshader){
$defshader_ = $defshader_ + "~" + $obj;
text -e -label $noshader_ -w 1 unshadedobj;
text -e -label $defshader_ -w 1 defshadedobj;
clear $noshader;
clear $defaultshader;
global proc select_unshaded(){
string $unsortedobjs = text -q -label unshadedobj;
if ($unsortedobjs == ""){
$unsortedobjs = text -q -label unshadedtext;
switch ($unsortedobjs) {
case "0 Unshaded":
print ("No Unshaded Objects! \n");
break;
case " ":
print ("Click Check first! \n");
break;
default:
string $unshaded[];
tokenize $unsortedobjs "~" $unshaded;
select $unshaded;
break;
global proc select_Defshaded(){
string $unsortedobjs = text -q -label defshadedobj;
$unsortedobjs = text -q -label defaultshadedtext;
case "0 Default shaded":
print ("No Default Shaded Objects! \n");
break;
case " ":
break;
default:
string $defshaded[];
tokenize $unsortedobjs "~" $defshaded;
select $defshaded;
break;
