hi ...
im use maya 2010 and i spent the last 4 days to make an awesome model in subdivision mode...
then i convert a duplicate to polygon to create a UVs layout and when i get finished;
i select the polygon model and the subdivision model (which in polygon proxy mode) and from mesh i take a transfer attribute and use it ...(nothing but UVs);
then inherit the polygon UVs to subdivision model and every thing work fine but....
when i try to go back to subdivision from the poly cage mode the standard command is not active ...
so pleas what can i do to solve this problem ?
thanks for reading
