Hi all,I can't figure out why houdini can't see my own RenderMan shader.I've added the environment variable as descried in the doc (RMAN_SHADERPATH,...) and created the directory as required.I'm using Houdini 5.0.94 on win2k.Thanks.-alexongaro
Did you read the docs that came with Houdini?Perhaps you should go over to www.odforce.netIn the tutorials section is a pdf for integrating renderman shaders into houdini.
