But it used to work correctly!
Is it better to export (I use mimics) as an ASCII stl for then importing to maya? I tried that, but the same problem persists!!
It seems to me that the only file format that I can export with mimics and import with maya is the stl type! Is this correct? Mimics also export as dfx, sli, slc, ply, but I can't import this files with maya, right?
Ah! Just remembered that I've recently installed Rhino 3D on my PC. Can this be the problem?
Thank's!
