Problems With 3d Painting Tool (ple)
Hi,
I have a question concerning the 3D Painting Tool. I use only the Personal Learning Edition and I'm an absolut beginner with Maya.
At the moment I am doing the tutorials in the "Learning Maya 6" book. I know it's old but that's what I got with my notebook.
Now I'm stuck in the second project called "Jack in the box". I assigned the eyeShader to the eyes and everything went fine. But after using the 3D Painting Tool and safing the project, now at re-opening it, the eyes are just plain grey and I cannot re-assign the original eyeShader or better it is not applied/displayed, the eyes just stay grey.
And painting them also isn't possible, because it says:
"Warning: Some surfaces have no file texture assigned to the current attribute."
Hope you can help me and the English isn't too bad.
If there are any other good resources I would appriciate links/tipps.
Thanks.
CYA Fightdog
Pler cant save anything that could nbbe used in other programs, and becase maya refernces textures it should now write files out fo that but see ple does not allow this so you cant get ple to remeber what you painted. Because that would mean you could export stuff out of ple (well you can anyway but thats another matter)
Hi,
so, do you mean I cannot render/texture anything with the PLE ? That would really suck.
But, the other stuff, just "normal" Textures, not edited with the 3D Paint Tool are remembered. So is it a problem with the Pant Tool?
CYA Fightdog
QUOTE(Fightdog @ 02/06/07, 11:49 PM) [snapback]259108[/snapback]
Hi,
CYA Fightdog
You can (but it will not last form session to session ), and offcourse you can use imported tesxtures painted in photosop or whatever. And you can only render stuff with ugly watermarks on it.
NOrmal textures come from a outside source so the textures allready exist on disk, BUT see maya must use textures on disk (maya files dont store textures, just references to existiong ones) to store stuff. NOW ple is cripled so that it cannot write ANYTHING usefull to disk, so that you cant abuse the thing.
Otherwise youd be able to use mya ple as a painter for textures for you other 3d apps. Now thats bad business. PLE is a learning tool not a making tool. The idea is to not enable you tod do anything usefull with it that you could sell forward.
