Post deleted by MarsChi1d
Well Hmm your problem seems so fuzzy but did you look at your Radeon fan because your card may be is getting very hot or your should use another driver version OLDER than your yours try it cuz may be the new one is not functioning well
Mars,
1-Is your motherboard overclocked? and brand of RAM do you have?
I noticed alot of people have problems with XP in general with this card. Perhaps you should try Win2K.
2-Make sure your card is set to “performance” in both OpenGL and advanced display options (i.e. anisotrop filtering off. or maybe even 2 or software preferred)
3-Turn off the Vertical Sync options.
This helped my machine when playing MechWarrior4. Didn’t crash nearly as much. My card has never crashed Maya. (however, it does crash while rendering if I overclock my box too much)
4-If it’s still crashing on games… do a benchmark test using 3D Mark2001- 2nd Edition. http://www.madonion.com . See if your machine crashes or freezes up on the test. Also, tell me what your score is ![]()
5-Are you using the .6071 driver?
6-if none of this helps, post your question on the Rage3D Forums. They helped me out alot. (post in the Radeon General) http://www.rage3d.com/board/
