I have a semitransparent bottle that is casting a raytraced shadow. It works fine in Maya Software but when I turn on MR the shadow is solid. it is no longer is lighter in the middle as it was in maya software. Do I need to set up some kind of sampler info for the lights vs. shadow color? seems unlikely. Tried messing around with the Ray Depth Limit but no good.
Hmm. this works fine for me. The only thing I can think of is that maybe global illumination is on. If GI is on, shadow shader is not exported by default, because shadow should be created using photons - lack of photons mean shadow. To use both the transparent shadow, and GI, maya 5.0.1 has a new option in render globals -> caustics and global illumination -> enable semi-transparent shadows. Don't know how to workaround this in 5.0
