I'm working on a project right now and the settings I'm told to use are 1080P/23.976 Fps. Fine. I'll be working in Maya and After Effects but right now I am wondering what the best setting for my comp in AE should be. Under the presets I am choosing HDTV 1080 24 as this is the closest setting that seems appropriate. There will be no filmed footage and everything will be generated on a computer.
When choosing this preset there is a dropdown option to change the frame rate of 24 to 23.976. Is this necessary? Is there a difference? Should I just keep the 24fps? There are so many aspect ratios and formats that I never know what to do. Perhaps if someone has the answer or a good resource for understanding this stuff that would be much appreciated. Thanks.
Jonathan
