Projecting curve on multiple surfaces
Is it possible to project a single curve onto multiple surfaces so that you can build a single surface from the curve on two or more surfaces. & does a projected curves component mode rveal the real number of cv’s on that curve. I have hundreds on rounded surfaces
Thanks for any help
I’m not sure what it is that you want to do but if you are maybe you should look into intersect surfaces. THat way you could have a tube or whatver that crosses or penetrates your curved surfaces and then use trim to delete the areas you don’t want. Sort of a boolean thing but with nurbs.
I know about intersecting surfaces but it present nasty texture issues, if im right maya interprets that there is the original surfac still there when you texture?
thought i could model somehow and have perfect texture fit
It would help if I had a better idea as to what you trying to model and how it should look?
I am trying to model a plane where i have two elliptical surfaces that intersect, then I want to add a third loft but in the centre of the two intersecting surfaces.
It works great with trim I just wasn’t sure if there was a way to project a curve onto the two of them and loft from that
