Hi all I new to Maya texturing. My problem is this. I built a nurbs mouse and want to put several logos on it. I've created a layered texture, with several different layers. I am using alpha channels and everything is fine until I turn off wrap, then it becomes only semi transparent. This only seems to happen when I have it set to projection, because it works ok when it's set to normal map. If anybody has a better way I would like to hear it. I'm using maya 6 right now. Please explain in detail, that would be a big help. Thanks
