I'm trying to set up an animated projector light. I have a simple test scene, containing just a spot light shining on a Nurbs grid.
Using the Slide1 Light Shader the light projection works, but Slide1 won't take pic sequences - only single images.
I've then tried FxDirector - this seems to be using the correct image, but scaled infinitely large, as the light adopts a single colour from the very centre of the image.
I've lastly tried the Bionic Light Shader, which (as I understand it) used on it's own should act as a projector, but this does the same as the FXdirector.
What am I doing wrong? Could someone shed some light on this? (ouch)
