Putting Animations on Tape - Help!
I’ve finished my projects, and now I need to go to tape. I have a 400MHz Pentium II with a 30GB IDE drive. It plays the animations too slow to lay to tape real time (via firewire), and I am trying to figure out what to do. I have been using uncompressed Quicktime, and I know that is not going to work. Now I have to figure out what compression to use. Preferably one that keeps a reasonable quality.
I’ve been researching in the web, and I’m lost in the CODEC wars. My capture card is cheap, and it doesn’t even mention what CODEC it uses. So, do I just need to find the right CODEC? What are some good compressions to use that don’t compromise quality of image?
Do I just need to get a good VTR that has frame-accuracy so I can lay down smaller pieces with less compression?
I’m quite lost. Nothing I read covers video editing from animation files–it all deals with captured video (that is already compressed).
I’d appreciate any ideas. Please note that I don’t understand too much of the video jargon.
one word (for everything): mpeg
unless:
if your doing cel animation: cinepac
MPEG is not the word…the word is digital disk recorder…try looking into DPS pvr or find a friend that has one. It is the only way to get all those frames onto tape.
good luck
allow me to clarify:
the mpeg answer is strictly for the cheapo card problem, fastest way to get ful res playback without dropping frames i assume your probably using udman drives as well then is mpeg. compression ratios cant be beat.
otherwise if you have the option, look into the above mentioned digital solution.
otherwise get a good ide drive, chuck it on a spearate ide channel and it should be fast enough using the DV Codec
otehrise get 2 ide drives and use NT’s software raid and raid them
should be fine
using the DV codec you only need about 3.6-5mbs sustained
most good disks will do it
theres a renderfarm company out there and they can send take your animations and put them on cd zip or what ever you want you might wanna see if theyd take your allready rendered scenes and put them on tape
the adress is
http://www.ren3d.com/
give them a try itll cost you money but im guessing less then some of the possible options here and this will be top of the line quality of your animation on tape
plus if you plan on submitting it to anything like siggraph or some of the other shows they want things in beta not vhs so just a thought
