PyQt in Maya2009?
How can i use PyQt in Maya 2009? is it possibl?
i copied libraries but dint work. got dis error:
# Error: DLL load failed: The specified module could not be found.
# Traceback (most recent call last):
#   File “”, line 1, in
#   File “PyQt4\QtCore.pyc”, line 12, in
#   File “PyQt4\QtCore.pyc”, line 10, in __load
# ImportError: DLL load failed: The specified module could not be found. #
but  QtCore.pyc is thr insid site-packages\PyQt4.
wat shud i do?
It is very possible. You can even use it in 2008.
PyQt4 and QT are not tied to Maya in any real way except for the new 2011.
The problem is, you must use a version that is compatbile for both your python version in Maya and the bit flavor of Maya (i.e. 32 or 64 bit).
If you want to run a version that works in 2009 I’d recommend 4.4.1 (there are compiles for 32 and 64bit).  I think you can run 4.5.x but I found 4.4.1 to be very stable.
HTH
Wel to be honest you can use pyqt with any verison of maya*. Its just a question of communcation channels between mayas core and your gui thats he thing you should do.
  • or any other gui toolkit you could ever imagine.
