Hi everyone!
I'm looking for the way to create in 3dsmax9, a QTVR movie; not in "Panorama" mode, but in "Object" mode, a so called "Object VR".
I have searched for plugin, script, that helps me to create from 3dsmax, but I've found nothing (cebas plugin is just for 3dsmax5-6-7-8).
Maybe there is a way to make it manually: to render all the frames of a camera animated along a circular path.
I don't know if there is a software that can helps me to merge then every single frame.
Any suggestion will be well accepted.
Thank you very much!
