Query Frame/animation Ext
How can I query the Frame/Animation Extension in Render Globals? Thanks!
QUOTE(Geegrafix @ 02/02/06, 02:20 PM) [snapback]227171[/snapback]
Hi
Yes u can query and you can modify also..
//now you got the current Type
  //1-9 you can get it
int $item = optionMenuGrp -q -sl extMenu;
//now you can set if you want
setMayaSoftwareFrameExt($item , 0);
//you can use 1-9 here insted of $item
enjoy
regds
o.S.k
the code above works offcourse only in gui mode if you wnat to know the extenssion outside of gui context you need to go to the nodeal source!
QUOTE(Joojaa @ 02/04/06, 03:35 AM) [snapback]227329[/snapback]
Hi joojaa
Yes it will work in GUI mode only...thts correct..
o.S.k
Sorry,
That didn't work...It returns...
Error: Object not found: extMenu
Thanks though.
QUOTE(Geegrafix @ 02/06/06, 06:24 AM) [snapback]227509[/snapback]
Sorry,
Thanks though.
Try this man
unifiedRenderGlobalsWindow;
window -e -vis 0 unifiedRenderGlobalsWindow;
regds
o.S.k
