I have Maya 2009. I’ve tried to use the Physical Sun and Sky feature (Windows to Render Settings to Indirect Lighting to Create Physical Sun and Sky). When I use it everything is all washed out. Any ideas.
QUOTE(mike_w @ 06/14/09, 07:21 PM) [snapback]309474[/snapback]
What is your monitors gamma? See what you se in vireports is not gamma corrected the result after render is. So you will nee dto adjust ALL YOUR color settings to compensate for correct gamma.
And yes it will make thing lighter see the viewport does not account for it so if you just put lights and assume its on and light based on thet you will get a MUCH overblown color.
Read:
