Hi all! i’m a new user of Maya (i;m switching over from 3D Studio) and had a couple of questions:-
How can I apply different texttures to different parts of a model? For example, if I want to apply different textures to the different sides of a cube, how do I do that?
How do I make a Blend material? For example, is there any way I take 2 bitmaps, put 'em one over the other, and then control their opacities to make a single “blend” texture?
Glows & Lans Flares: How do I make them?
I know these questions may seem a li’ll too simple, but I’d appreciate any/all help. Thanx!
open hypershade select the face, rightclick on material you want and choose assign to selected objects.
connect the tho materials toi a blend node and anmate the blend value (note theis value itself can be an animated texture too if you so desire)
Assign something to glow channel of the material, for lens flares add a flare to your light. But this is sometrhing i would avoid doing in 3d! i would instead look into doing this in a comp app for best possible controll.
For further info hit f1 its described in the render section of the manual.
Apply Material to Selection
You can just add materials to whats selected, so if u show faces on a poly cube & select a face, right-click & go Materials > Assign New Material, it will only be applied to the selected face.
Material Blend
Maybe u prefer Using Layered Shader type, where each layer can be another material & you can set opacity for each layer.
Glows & Lensflares
Geometry
Select the object, open Attribute editor, find Special Effects > Glow Intensity, A good effect is to create a duplicate of original object, scale to be slightly larger & apply the glow to this object & enable “Hide Source” to only show the glow of the outer duplicate.
Lights
Select a light & open attribute editor, find Light Effects > Light Glow, hit the link button to open glow/flare options.
Im a noob too & am sure there is probably more to be known on these subjects, which I wouldnt mind knowing myself.
