i started workin with python yesterday, and i am absolutely amazed by the EXTREME flexibility that it has, yes i have fallen in love!!
focus isam focus! back to the point, i am trying to set a an MPoint to specific numbers i got from a file, but the initializing is workin if i set the number manually, like point = OpenMaya.MPoint(0,0,0,1)
but if i try to set it up tthru a variable,
point = OpenMaya.MPoint(coordinates) (coordinates is an array of size 4)
i get this error,
# Error: in method 'new_MPoint', argument 1 of type 'float const [4]' # Traceback (most recent call last): # File "", line 1, in # File "C:\engserv\rbuild\208\build\wrk\optim\runTime\Python\Lib\site-packages\maya\OpenMaya.py", line 5278, in __init__ # TypeError: in method 'new_MPoint', argument 1 of type 'float const [4]' #
i know its sth really easy, but i wish i cld get some help here
QUOTE(isam @ 11/08/07, 09:45 AM) [snapback]276186[/snapback] point = OpenMaya.MPoint(coordinates) (coordinates is an array of size 4)
i get this error, # Error: in method 'new_MPoint', argument 1 of type 'float const [4]' # Traceback (most recent call last): # File "", line 1, in # File "C:\engserv\rbuild\208\build\wrk\optim\runTime\Python\Lib\site-packages\maya\OpenMaya.py", line 5278, in __init__ # TypeError: in method 'new_MPoint', argument 1 of type 'float const [4]' #
Yeah, you can't exactly do this ... the constructor is expecting individual floats. Fortunately, you can "explode" the array. I personally don't see this in a lot of Python code (possibly for a good reason - I'm not sure), but here you go:
thanks 4 the response, but this doens t work either, the problem seems to be coming fro mthe variable, as if i set the c to
c = [ coordinates[0], coordinates[1], coordinates[2], coordinates[3]]
i seem to be getting the same error as before
# Error: in method 'new_MPoint', argument 1 of type 'double' # Traceback (most recent call last): # File "", line 1, in # File "C:\engserv\rbuild\208\build\wrk\optim\runTime\Python\Lib\site-packages\maya\OpenMaya.py", line 5278, in __init__ # TypeError: in method 'new_MPoint', argument 1 of type 'double' #
your apparently trying to pass in worng types (such as int or string whan you need double)? This happens sometimes between non/strongly typed interfaces.
If you just domp your data it dont get cast as far as i know but im not sure. i never use the * because it contains a slight caveat.
