Hi all! ![]()
I`m new XSI user without SI|3D experience.
Can u help me to add a random behavior to any object [in this case-effector position] ? Can u give me some tips?
thanx! p.s.[3dstudiomax has "Noise Controller", Lightvawe- "JitterMotion", and XSI ? ]
hi there,
The original Jitter effect from Softimage is supposed to be implemented in 1.5 I heard, but there's different ways of jittering objects.
If there's animation on the obj, a random expression on the local transformation would do the trick RAND(seed,value1,value2)
Or try deform->shape jitter. It's more for jittering points and clusters, but if you crank the 'group vertices by' slider higher than the number of points you have, the whole object jitters.
Hope that helps, if it didn't please let me know.![]()
