ok, I've looked over the HOW-TO install and its so straight forward I can't beelive I can't get it to work... basacally, the default file path is correct .
C: Program Files/Aliaswavefront/mental Ray for Maya...
anyway, thats where I have my Maya 4.5 , at its default.thats where I think I WANT IT ....
.but ..
the MayatoMr plugin is not showing up to turn it on..and when I moved the mayatoMr plugins out of the directory and into the directory ..
C: Program Files/Aliaswavefront /bin/plugins..
you see...this should be RIGHT...
it shows up,sure... but won't load!! ..it errors out..
If anyone can make sense of my issue..let me know. I certainly can't , and I'm feeling rather dumb.
At the wits end , its driving me nuts..anyone else have any issues ? or just me ?
HELP ...THANKS..or call the white van couse I'm going loony.
ok I guess i am just handycapped..becouse shiot..I've tried all i can think of and still no plugin to turn on in the plugin manager... and its in the file path it wants to be in as far as I can tell.. I mean, you guess just ran the installer right? and it worked? Wonder what is up.... large cloud of burnt char rises from head
yea, thats where it is..and nothing . its not working. odd eh ? the plugin is not seen in my manager... yea i'm jsut doing the default , and nothing.. makes me wanna cry . thanks though... maya is installed default as well.
Obviously i would recomend checking to see in the enviroment variables, to see that everything is kosher. I say this because sometimes with certain systems, a space between program files as compared to progra~1 might be a screw up. Make sure things are pointed in the right direction.
you know what? Maya is in the right place..the default install..but who knwos about my envirnments... screw with them more than I should..good headsup. I'll look at them.
ok, on this computer..still no luck. Heres my errors..anyone have ANY idea ? Look at the path,..does that look right? I just do basic , default install.
loadPluginCallback "C:/Program Files/AliasWavefront/mental ray for Maya 1.5/plug-ins/Mayatomr.mll" "plug-in"; // mental ray for Maya 1.5 Public Beta // Error: Cannot find procedure "mentalrayForMaya_v15". // // Error: (Mayatomr) : setup command execution failed // // Error: initializePlugin function failed (Mayatomr) // // Result: 1 //
ok as far as system envirnments ..heres the only thing I can find that said mray anywhere...
there is somthing called
path
C:Program FilesAliasWavefrontmental ray for Maya 1.5bin
Who knows whats up, other people have put odd things on this system. I've cleaned a lot up . no time to totaly re-haul.. but maybe I have to. Ok, so does this look right at all ? man, so horrible..not letting anyone touch this box anymore to screw with graphics...interns... ARG! haha. if this looks right then I take it back.
bah, i installed it on another system..it works fine..guess my computer is f'ed up somehow.. going to copy my envirnments from the working on and see what the diffrerences are.
hey! I went to work this more and the damn Mray plugin showed up...why ? I don't know . Freaken mystery. But I'm happy now..maybe a power surge got windows to work or maybe some norton utility went off in the night and fixed somthing...freaken month long nightmare.
