i have 2 passes of a pan accross a room, which are supposed to be at identical speed. they need to be layered one above the other, so that one can blend to the other as the pan takes place. simple stuff, except they're not quite at the same speed!
does combustion provide any decent re-timing features, or any at all? i know how to do it in AE but the removal of frames makes it appear slightly jerky. i am aware that there is specialist software that minimises this, but i don't know how it works or where to get it.
cheers,
alex
Hi...
Read my Tip/Trick that is posted here:
http://www.fxguide.com/fxtips-255.html
That should tell you everytthing you need to know...
Read a list of almost fiftyCombustions Tips/Tricks here:
http://www.fxguide.com/fxtips-list-8.html
bye,
jack.
denmark
