You don't want to change it. That's your default shader that gets assigned to everything new that you build. You can easily see if you have forgotten to assign a shader to any objects in your scene by right-clicking on "Lambert1" and selecting "Select Objects With Material" - they'll get highlighted in your scene.
If you change the shader, and the name and all that, it will still get assigned to all new objects. Best to leave it alone.
