$lst=lsUI -ctl -l;//or without -l
for($ACtrl in $lst)
print objectTypeUI ($ACtrl+"\n");
// Error: line 5: Object not found:
it lists :but I cannot access objects.
this is a restriction ? or the day is wrong for me ?
thanks.
for($ACtrl in $lst)
thanks.
QUOTE
You've got a bad semantic error
You mean to wirte:
print (objectTypeUI $ACtrl+"\n");
But yes obviously since no name ends in \n, its nit syntax error because it is possible that a string could contain end of line at the end tough why would you add the "\n" is beyond me this SHOULD be the same:
print (objectTypeUI $ACtrl);
