Redirecting command output to two files
is it possible to redirect the output of a command, say cat, to two files simultaneously?
cire
You could cat and then cp.
ls -l | cat > test && cp test test2
or if you need to append to both files.
ls -l | cat >> test ; ls -l cat >> test2
I'm don't know of a way to append with cp and also I can't get a line where i can double pipe the output. Not really into bash scripting currently but it is a nice skill to have.
You could use tee. Example:
cat src_file | tee dst_file1 > dst_file2
