i`ve imported an eps Logo but there are to many points...
how can i reduce points before i create a curve on surface ... smooth does not really work
Go to Edit Curves > Rebuild Curve, in the options change the number of spans.
yeah thx jpatel 8]
it works quite good. but...there is more...
if i projekt the curve on my Nurbs Surface to make some relief stuff with the imported eps.logo
the points a reduced are back again !?
did i forget something. why is it like it is?
Try selecting the curve you're projecting. Under Outputs>Project curve, change Use Normal to on and adjust the tolerance. This will change the shape of the surface curve if the tolerance is set too high, so you have to play around with it to get the results you want.
Hope this helps.
jpatel
