Reflections of Reflections
I’m using Mental Ray (with Final Gather) to render some HDRI tests I’ve been doing. The scene includes several primitives, each with a blinn material. In my finished renders, each object and the environment is reflected in the other objects. However, these reflections don’t include highlights and reflections themselves. The result is that the reflection of one sphere on another, for example, looks very flat and doesn’t, itself, contain any reflection of the surrounding environment or the other objects in the scene. The objects all have a blinn material applied to them but in the reflections, they all look like a flat lambert.
I have tweaked Mental Ray’s max reflection values, as well as reflection depth, under the Rendering tab, but don’t see any noticeable difference.
What am I missing?
Thanks a lot.
Did you raise the reflection limit under the raytrace options tab in the shader itself?
