Ive been having troubles with windows not refreshing on monitor 2 of my setup. Im running a 21" NEC and an old 15", on a Geforce 4 TI4600. i have this prob on all my systems, so i dont think its a hardware shortcoming or failure of anykind. I dont think its the refresh rate limitations of the 15" either, because i have another system running dual 21" NEC monitors. In addition to this, one of my friends is having the same prob with his dual 19's. All these systems are running ti4600's excpet for one running a 4400. I had maya installed before and didnt have any probs, maybe i adjusted a setting i forgot about, and when i built my new system, i forgot to reset it. The Hypershader and object view windows are especially a problem, they will not refresh at all. Any help would be greatly appreciated.
If you are using Nview, you may want to try turning off the Nview desktop manager after you have assigned your programs to one monitor or the other. They will remember your settings. This may not be the problem but it's worth checking.
-CS
Kind of hard to tell since you don't mention your OS. Either use nview instead of dualview (wich would be defaqult in XP) or go to OGL tab of nvidia controls and enable advanced multiple monitors.
i was having problems with refreshing on my second monitor in xp with quadro 2 mxr until i updated drivers to detonator version 29.80. i am using beta version 30.82 now, it is stable and i havent had any problems. you can get the betas at http://www.warp2search.net/download.php?op...nload&sid=2
