hi
I want to remap the to global, local, and view axis buttons on the transform panel to hotkeys, but cant find them listed in the remapping keys window. Is this possible.
thanks
hi
thanks
You can do that through scripting. Basically you create the script, then you assign a key to the command. The script is very simple:
SetUserPref "3D_TRANSFO_REFERENTIAL_CHANGED",
where is one of the following numbers:
1 -> Global
2 -> Local
3 -> Ref
4 -> View
6 -> Parent
7 -> Plane
Hope this helps
Salutations - Cheers
Bernard Lebel
