Remove flickering
Hi there,
I am searching for a solution to minimize flickering. Due to thin lines and low antialiasing of a 2D animation production horizontal lines in a PAL resolution tend to flicker. This can be minimized f.e. by applying an anti-flicker filter that blends the field into each other (f.e. 3Prong's twitter fix for avid symphony). I am searching for a similar solution that can be applied in combustion, shake or after effects. Partly, this problem can be solved as well by applying directional Blur. Any info on this issue is greatly appreciated.
Thanks,
Liliana
