Using 2008. In previous versions I remember it automaically rendered all renderable cams. But that doesn't seem to happen in 2008. I don't particularly want to send it all to command line if I can help it.
QUOTE(gmask @ 11/03/08, 11:01 AM) [snapback]294440[/snapback]
In any version you can simply enable rendering for each camera and they will all render with one render command.
you could also specify which camera you want to render on the command line with the -cam flag
in newer version of maya you can easily add additional cameras in the render settings
which version of maya are you using?
