@@does anyone know if it is possible to define the order of how passes are rendered?I mean,normally it renders like this:
pass1-frame1,pass2-frame1 and so on,but i want to render first the hole first pass then the second because its much faster that way...
no script necessary - this is the default behavior with XSI v2.0 which should be on your doorstep very soon.
But if you must script, just access the passes list with GetCurrentPass() and render it, then follow by setting the current pass to the next in the list and so on using SetValue().
Matt
Matt Lind
Animator / Technical Director
Softimage|3D
Softimage|XSI
speye_21@hotmail.com
