hello everybody ; got a script that worked fine before; but no more to render sub regions:
get a scriptt wich allows to render,different regions with Maya renderer:
global proc get_RenderRegions( int $x_res, int $y_res,
int $x_reg, int $y_reg,
string $image, string $file )
int $x_step = floor( (float)$x_res/(float)$x_reg );
int $y_step = floor( (float)$y_res/(float)$y_reg );
if( $x_res % 2 != 0 ) {
error( "X resolution must be even" );
if( $y_res % 2 != 0 ) {
error( "Y resolution must be even" );
int $x, $y;
int $image_index = 0;
for( $x=0; $x<$x_res; $x+=$x_step )
for( $y=0; $y<$y_res; $y+=$y_step )
string $command = "Render";
$command += " -x "+$x_res+" -y "+$y_res;
$command += " -xl "+$x+" -xr "+($x+$x_step-1);
$command += " -yl "+$y+" -yh "+($y+$y_step-1);
$command += " -im "+$image+"_"+$image_index;
$command += " "+$file;
print( $command+"n" );
$image_index++;
Then, i type for instance:
get_RenderRegions( 6000, 6000, 3, 3, "pane", "C:tempballs.mb" );
Maya script editor,then give 9 lignes ,as following:
Render -x 6000 -y 6000 -xl 0 -xr 1999 -yl 0 -yh 1999 -im pane_0 C:tempballs.mb
Render -x 6000 -y 6000 -xl 0 -xr 1999 -yl 2000 -yh 3999 -im pane_1 C:tempballs.mb
Render -x 6000 -y 6000 -xl 0 -xr 1999 -yl 4000 -yh 5999 -im pane_2 C:tempballs.mb
Render -x 6000 -y 6000 -xl 2000 -xr 3999 -yl 0 -yh 1999 -im pane_3 C:tempballs.mb
Render -x 6000 -y 6000 -xl 2000 -xr 3999 -yl 2000 -yh 3999 -im pane_4 C:tempballs.mb
Render -x 6000 -y 6000 -xl 2000 -xr 3999 -yl 4000 -yh 5999 -im pane_5 C:tempballs.mb
Render -x 6000 -y 6000 -xl 4000 -xr 5999 -yl 0 -yh 1999 -im pane_6 C:tempballs.mb
Render -x 6000 -y 6000 -xl 4000 -xr 5999 -yl 2000 -yh 3999 -im pane_7 C:tempballs.mb
Render -x 6000 -y 6000 -xl 4000 -xr 5999 -yl 4000 -yh 5999 -im pane_8 C:tempballs.mb
type those in prompt but -xl : invalid flag what's wrong ???
