QUOTE
Then in the detailed message thingy it says:
"Warning: Image file cannot be output. Please check your file permissions and ensure
that the current project has an images directory."
Before going further, did you checked the file permissions and ensure that the current project has an images directory ? (after all it's what Maya is asking you
Which means do you have a proper project with subfolders like "scenes" and "images" , with the scene you want to render into the scenes folder ...
If not, you have to create (or set) your current project using the file|project menu.
BTW Maya is supposed to have a project by default (under Documents and Settings/~username/My documents/Maya/projects) , used when no other project is set. Maybe this folder is in read-only mode ?
Sorry if you knew and checked all that already but I had to ask to be sure ....
Guyb.
