QUOTE(thirt33n @ 11/12/06, 07:12 AM) [snapback]252213[/snapback]
Error: An error has occurred. Rendering aborted.
Error: an error dialog box popped up. Caption Was:mayabatch.exe - Application Error
Unfortunately, these are two of the least useful Maya error messages available. The most common causes of these errors are:
* Your scene is consuming too much memory, causing Maya to crash.
* Your scene is corrupt, causing Maya to crash.
* You have a texture that is corrupt, using the wrong byte ordering (i.e., it's a Mac TGA instead of a PC TGA), or truncated, causing Maya to crash.
* On rare occasions, rendering to formats other than .iff have caused these errors to appear. Try rendering to .iff format instead.
Found this on one site, hope it helps.
yeah it helps thanks a lot...
