Rendering Fluids: "copy locally" pains
Maya Unlimited 5.01
Linux Red Hat 7.2
I'm rendering across a network with fluids and I find that copying fluid caches locally is really straining our network & server. I know that as of Maya Unlimited 5.01 there is an option to turn off "copy locally" but I am running into a problem that I hope you can help me with.
These are the steps that I am taking.
Create the cache and save the scene with "copy locally" turned ON
Save the scene again with the "copy locally" turned OFF
Now when I select the fluid it says that it cannot find the cache. When I go to check the path name in the fluidCache node it seems to put the name of the file somewhere in the middle of the name of the saved cache. For example.
The scene name:
AA_NN_000_Flare.1.mb
The FluidCache name:
AA_NN_000_Flare.1.mb_fluidShape.mcfp
The result as reported from Maya:
data/AA_NN_000_Flare.1.mb_ProjectName/Shots/ProjectName/data/AA_NN_000_Flare.1.mb_fluidShape.mcfp
The result of the path SHOULD be:
data/AA_NN_000_Flare.1.mb_AA_NN_000_Flare.1.mb_fluidShape.mcfp
or
ProjectName/data/AA_NN_000_Flare.1.mb_AA_NN_000_Flare.1.mb_fluidShape.mcfp
I'm not sure why Maya is having a hard time with the path but I though I would see if you guys had any soloutions.
It seems that there is a bug with handling of underscores in cachenames(we have logged the bug thanks to your post). If you can change your names to avoid underscores ( perhaps changing to "-") then hopefully things will work for you.
Duncan
Argh - looks like this bug is still there. Maybe in 2008? :stuck_out_tongue_winking_eye:
I couldn't find the original bug report for this. Could you enter a bug with support? I'll re-enter this post as a bug, but your specifics would be more helpful.
 Duncan
I found the bug... 199751 if you want to inquire. It has not yet been fixed.
Duncan
