Hello.
I try to render a scene using python render command with Maya2009. In
maya interface, render is working but if I use mayapy.exe program, my
render freeze (no error, just freeze). If I use MEL render command,
render is working.
My render freeze only when I assign a surface shader on a mesh.
I’ve made a sample in attachment:
- renderPy.bat launch mayapy.exe (in maya 2009 folder) and run script render.py
- renderMel.bat launch mayabatch.exe (in maya 2009 folder) and run script render.mel
render.py and render.mel contain exactly same commands: set workgroup, open scene and render image
Each script render test_ok.ma (a cube with a lambert shader) and
test_freeze.ma (same cube with a surfaceshader and koala.jpg picture)
Do you have any idea why render command freeze in python implementation?
Thanks
Attachment test: [url=http://www.sendspace.com/file/fk6jbx]http://www.sendspace.com/file/fk6jbx[/url]
