Well not those no but you can do the same thing, because in reality its just a different name for a special use.
There does exist a node that does the same thing that the ghost option, namely the animated snapshot node. Since this node actually creates real geometry you should use it instead. What you do is just animate the end and start frame of the snapshot node and it does the same thing.
