When rendering with Mental Ray, I finf myself messing around with options to achieve production results for a final image. I am rendering with Final Gather on.
My question is, What settings should I configure to give me at least perfect anti-aliasing and clean shadows without any artifacts on my objects and shadows?
not too sure what your asking for - sounds like you want both good and bad quality your artifact problems lie with FG. there will always be artifacts with FG at low quality, sometimes even at the highest quality if you havn’t configured it properly.
probably best to experiment without FG first to see how global settings affect shadows and edges. global samples effects aliasing quality, in most cases 0,2 gives good quality - 1,3 is only necessary in a worst case scenario. you should never have to use 2,4. your images will take 10 times longer to render than a software render.
as for shadows i really like mental ray’s raytraced area lights. you can set sampling on the light itself and in experiments i’ve found them to be about twice as fast as maya’s area lights, give awesome realistic shadows.
adding FG changes everything, FG quality is entirely dependant on the number and type of objects and lights in the scene, the scale, and a hundred other things. you have to experiment and set min/max radius values. i would recommend searching this list for previous discussions on that. quality FG renders are really slow, theres no way around it.
