@ ightningad: Yes, i have QT7 and i am able to render avid quicktimes with AE no problem. I can also open and play avid quicktimes in QT7. I dont have the problem you describe.
QUOTE(beaker @ 02/24/06, 10:15 PM) [snapback]229241[/snapback]
What resolution are you rendering at? The avid codecs only support a few different resolutions otherwise it will fail (720x480).
As mentioned, rendering quicktimes from AE works, and i am aware that it supports only the standard PAL and NTSC resolutions.
