Rendering Video In Maya 8.5?
anyone know how to render video in maya 8.5? i used to know how but i usually just render images and everything is great, i really forget how to do it
step by step as best as anyone can? please? lol
set the type to avi on windows or mov on mac.
Anyway you really shouldnt render directly to video theres 7 very pressing reasons not to do so. Do images and then convert those to movies its a better workflow.
it seems like that would be really choppy just to render stills
Well, yes if you think terms i want animation only. But you need to think of what that move involves, you could equaly well say gasoline what do i need it for* i just want my car to move form point A to B.
However consider animation files for a minute, hat are they? They are just individual image files which are globbed and compressed together, they are choppy. Now the magic reason for why you’d want to have the image files separated is in that sentence.
let as analyze it. theres parts there that hint of the procession. globbed images and compression. Lets talk of compression first.
Compression, means to shrink the size of the file, some of this comes form analyzing changes in the file and some of it by downgrading the image. It so happens not many users out there have a computer thats actually fast enough to show uncompressed footage. It does not matter tough humans aren’t so accurate in their vision anyway. However this has a snag, its hard to know what compression settings yield good results. Secondly the images need to be known when on segment of the movie is done, sometimes this segment is fairly long and thus you’d need to render many images before you could begin doing the compression. Theres a second snag on the way, in general (ive sen one it cost a lot and could use 2 machines only) only one computer can work on the compression.
Now then let us consider globbed images, well so the video file is individual images anyway, so why not store them in that way before turning it into a video? If you choose a lossles format you have the same as a video but with more lookup options. ill come back to this in the main list.
So if you didn’t figure out at least 1 implication of above let me list a few of them for you:
[ul][li]What if the compression was bad? Well you’d need to re render the entire animation, however making the images takes 90% of the time and compression even good one at most 10%. So had you rendered the images you’d used a bit more disk space but would have at least tried 20 different compression settings in same time that you did try 2 with rendering to videos. But maybe best of all you got 1 compression for those guys who had a slower network bandwidth for example for free![/li][li]What happens if you have a bad image mid run, you’d need to render a big chunk anew because it can affect following images, worse you now can have hard time identifying that frame. Well anyway had you images it would be easy to fix just that one image. You could even jut retouch it quite quickly in your image editor.[/li][li]What happen if for some reason a image drops out, renderer crashes or halts or worse you have a power shortage. Then you’d have to start the entire sequence forms start again loosing valuable time.[/li][li]Scalability, when your in real production you use lot of machines at the same time, it wouldn’t just work out very well, and youd need one computer dedicated to compressing. Something you could do in any stage anyway.[/li][li]The rendering is rarely the last step in the production so it might need to be integrated in live footage in pot, or layered, and comp apps readily accept individual image files for same reasons as rendering. But also the lookup cn be faster then a highly compressed image even if its lossless, since each segment needs to featch last frame potentially many to calculate the current. Which mean a sequence can be faster to lookup on a monster system with fast disks.[/li][li]Theres essentially only one downside to having individual images and thats the fact that it may under some circumstances use more disk space. You can even view the image sequences as videos if you like, they can even appear as one file n your operating system, even tough they arent. So form yoru point of view they’d be equal to a uncompressed video file.[/li][li]All this brings you more production flexibility so instead of locked options you have now much more artistic freedom on production side, you can avoid compression re-compression events. Use much more varied tool set. Just remeber to store the originals [/li][/ul]
Now odes it still seem choppy. Essential because it does not hurt you in anyway and can give you more value than not doing into images. But mostly because some of these issues are ones that make and break careers and companies.
  • the question of gasoline need is a good one, the answer is that its a cheap source of power, or at least was but we used it to pump up the market economy artificially, it will soon be gone. Seems like the price we pay for this at the moment is quite extraordinarily high, nnot just in form of raw fuel. But also the global consequences.
Ever showed up at work and found out, that your over-night render job crashed at 95 %?
Short and simple, thats why you render frames. An AVI would have been 100% lost, with frames you would only have to rerender 5%.
Nuff said.
