Can I also render Wireframe in XSI?
Yes you can. There are 2 ways to do this.
1- Use the Capture function. In the camera viewport, set the display to wireframe, click on the cam icon and choose Start Capture. There you have output options. This is good for quick previews.
2- Use the Toon Shader. Here I can't help you as I don't have experience with it. However, it is described in the manuals in the Shader, Lights and Cameras manual > Blurs, Flares and Others Effects > Creating a cartoon effect.
If not, how can I make a uv-snapshot, to use it as a texture?
First, you must apply a texture projection to your object. Then, select this projection in the Explorer (in the clusters), and open the Texture Editor. Then Edit > Stamp UV Mesh.
Hope this helps
Salutations - Cheers
Bernard Lebel
