How use photonic information on RenderMAp??I want get GI on my ilumination maps!! How to do it????
Select the object. Get>Property>Rendermap Set the file name. Compute the map.Done.
Make sure that you have GI turned on in your render options too. (not just your render region options)
Since you are rendering off the normals of the object, the settings are a bit different because distances are not in the same range as your camera viewpoint. So like Ed said you have to tune using your render Options FG settings.
